Oil
Originally Posted by Shinerbock07
Seems to thin....i use syntec 10W-30
Originally Posted by Patman
It's not too thin. Even though it's a 0w30, it's actually thicker than the 10w30. The first number just means it will flow better in extreme cold. The second number means it has a viscosity of between 9.3 to 12.4 cst at 100c. Syntec 10w30 has a viscosity of 10.0 cst at 100c, while the Syntec 0w30 is 12.2 cst at 100c. So it's a lot thicker when hot. But it will flow much better in extreme cold. It's the best of both worlds. And because it uses a super trick base oil, it does not thin out like a lot of 0w30 oils would.
