Just put B&M supercooler on dope style
Moderator
Dope style will probably not see much air until you are rolling.
It is not close-coupled to the fans and air probably prefers to
sneak around, rather than through. You might consider adding
a 12V PC muffin fan or something, if you find it's not doing
well (as seen by ATF temp readings) at low speeds.
