NE ONE Ice there intakes down for improveing ETs
Just curious as the LTx engines are quite hot for long periods of time. I am looking for before/after if you have iced your intakes down, or used a Pro Cooler bag to reduce your intakes temp.
Daren
I was going to use those gel packs, to "ice it down". I normally leave around 200 degrees, water temp, so I know that isnt helping much. But, with the exception of the tires, I like to run it as if it is on the street.
Originally Posted by MrBill97396
On a street car why waste your time I mean really. I love the things that all my fellow LTX owners ask.
Moderator
We tried it on my LT1 and pushed it through the lanes, car didnt hook so I didnt see a change. The funny thing is, my best passes are usally right when I get to the track, tech it in and make run, not much cool down time but for some reason maybe the tires being warm from the drive or what, they car always lays down the best number the first hit
Me too. Never thought about it being the tires. But, I did always wonder why.
Do more of a burn out if you think it's the tires.
I usually try get back into the staging lanes as fast as I can after making a pass, which at most tracks puts you closer to the front of the line in that lane, that way after a few passes I'm first in line and when I ice down the intake I litterally get to start the car and pull into the burnout box right away, not heating it up again, and you can see a big time improvement.
Originally Posted by slow96z
I sit in the staging lanes with the AC on and watch tv until it's my turn to beat an LS1.
Icing the intake will give you results, but it's only worth it if you can keep the car off until you run. Like some people said, push it up the staging lanes.
Have you seen actual time differences. I know LT1's run better cool. Just havent seen a real time , other than the post above.
Originally Posted by blkchevyz
i stopped doing it becuase i would need to let it warm up to get into close loop anyway... car always ran faster in close loop.
Makes absolutely no difference at WOT, it ignores the O2 either way, open or closed loop
