Manual Transmission - Clutch and bellhousing for 900hp
View Full Version : Clutch and bellhousing for 900hp
69 ls1
03-18-2006, 10:59 AM
Anyone know what the best clutch/flywheel combo there is out there to hold about 900 flywheel hp. also What is the best or strongest bellhousing made. If anybody knows info or has recommendations that would be awesome.
CTSmechanic
03-20-2006, 09:38 AM
Best? Tilton Carbon/Carbon with a mag bell housing... huge power good driveablity
69 ls1
03-21-2006, 08:15 AM
how do i go about tracking this setup down ( where do i buy )
CTSmechanic
03-21-2006, 08:37 AM
Im not sure if you can purchase direct from Tilton or not you can sure call them and they'll help you select your componets they have an exelent support staff... Check out Tilton Engineering.com for the contact.If you cant purchase direct they will be able to point you to a good dealer....
