Cartek 2x dyno
Old 03-18-2006, 12:05 PM
MagikMan's Avatar
Default Cartek 2x dyno
I had my car dynoed today. This is on the mail-in tune. Mods are in my sig:
416rwhp and 383rwtq A:F 13.2:1
Old 03-18-2006, 05:13 PM
MagikMan's Avatar
This is on the mail-in tune.... The guys at the motorshop said I could get about 15-20more hp out of a tune... I also got the 30lbs injectors. So that's a good thing. Hopefully we'll be seeing some 440hp numbers soon
Old 03-18-2006, 05:42 PM
LS1 Tech Administrator
Patrick G's Avatar
If your A/F ratio is already at 13.2, you're probably not going to pick up 15-20 rwhp with additional tuning. Timing makes a difference, but most mail order tunes get the timing pretty close. I hope you can find some additional power with more tuning. Enjoy the newfound power.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-19-2006, 11:39 AM
sickss228's Avatar
What heads do you have 241's or 243's castings, gears? Reason being is that I've seen a couple Cartek 2x cam only vettes (M6's) make 410 RWHP. You should of got a tune from Cartek they will get you to the 440RWHP+ that their 2x package has been making for years. Also they have tuned tons of these setups and know how to extract every last bit of power unlike a tuner who didn't design the package. Give Dave (908) 317-4496 a call and see what he says because these numbers are extremely low for a Cartek 2x H&C package.
Old 03-19-2006, 08:55 PM
MagikMan's Avatar
i'll post the graph.... but when you look, I think i need new spark plugs like crazy.... and everything will be good
Old 03-22-2006, 07:54 AM
MagikMan's Avatar
Old 03-22-2006, 08:25 AM
bad95killer's Avatar
Nice #'s man
peace
Old 03-22-2006, 10:29 AM
Patrick G's Avatar
Thanks for posting the graph. The mid-range numbers at 3000-4000 rpm tell a lot about what's going on with your setup. I hate to even bring this up, but your dyno graph is based on the STANDARD correction. Most on this board use SAE correction. SAE numbers tend to be a few percent lower than STANDARD numbers which means you're making even less power than the 416/383. Sorry.
Hopefully with fresh plugs and additional tuning, you'll find the missing ponies.
__________________
Old 03-22-2006, 10:42 AM
SideStep's Avatar
Just wondering, you are running no cats, right???
Old 03-22-2006, 11:54 AM
MagikMan's Avatar
how could you tell?
Old 03-22-2006, 03:05 PM
WS-Sick's Avatar
In the upper left corner the is "STD" written. Your car still made what it made...it's just that SAE numbers are usually lower because it factors in different variables such as altitude, weather, etc. Still pretty good numbers. I know it drives like stock and pulls pretty hard and the dyno you ran on might dyno lower than others as well. I bet it pulls pretty hard now huh?
Old 03-22-2006, 03:53 PM
Ksett's Avatar
Originally Posted by MagikMan
MagikMan, unfortunately those numbers are standard numbers and I know that dyno. I think you are about 400-405 SAE rwhp. I had a baseline done on my car last week at Excessive and I dynoed 413 Standard and 400 SAE.
After 2 pulls I realized he was using Standard numbers and had him change to SAE on the last pull. Right now I'm cam only with an F13.
Old 03-22-2006, 04:20 PM
MagikMan's Avatar
yeah I ran like 5 minutes after you left :-P I was mor concerned with the A/F actually And it sucked... I called up cartek and they told me I should be around 430-440 when they are done with it. I picked up a set of SVO 30lbs from excessive and they only charged me 125 for them. They are used, but in great shape... So I'm going to take a trip up there. Right now I'm putting in 4.10's and a hardened output shaft... we'll see.
Old 03-22-2006, 04:43 PM
dynocar's Avatar
Question #1, why would "standard" read lower? #2, why would any dyno shop use "standard" if the dyno readings can vary due to the location's elevation or atmospheric pres, temp and humidity of which SAE is used to standardize? Maybe I have my terminology reversed.
Old 03-22-2006, 05:02 PM
Ksett's Avatar
That's cool. I could recommend someone locally for a speed density tune but I would take the car up to them since it's there package and let them figure out the problem.
Old 03-22-2006, 05:52 PM
H/C LS6Z's Avatar
I like that 2x cam more and more I hear about it. Did you ever dyno it cam only? anybody ever dyno this cam cam only? I really like the specs/power/track times that Cartek claims it will do.
Sounds like good #'s to me man, congrats!
Old 03-22-2006, 07:06 PM
MagikMan's Avatar
Yeah, and I'm on the super low end of what people dyno with my setup
Old 03-24-2006, 10:54 AM
Rescue Ranger's Avatar
Hey man.. I've been following your setup. I have an 02 Z28 and went with the 2X Cam (mine has a little less lift than yours I think, .581/.588 on a 224/228 113lsa).
Its possible a better tune would help you out
an area in which I have no experience but am curious about.. the stepped 1 7/8 headers aren't too big?
Still your numbers are pretty good. Get an extra 10-15ponies otu of that w/ a ls1edit and I'd be pumped. A pulley maybe?
I'll compare my dyno graph; my car goes into East Side Performance on 3/29 for Cartex 2x cam and Patriot S2 59cc heads, pulley, pacesetters, ory, magnaflow, and a LS7 clutch, with LS1Edit tune. Expensive but hopefully it'll all go smoothly and It'll be worth it.
Old 03-25-2006, 02:40 AM
MagikMan's Avatar
Yeah definitely... I'm going to be broke here for a while till I can afford to put the injectors in and get it tuned.... my output shaft broke at the track so now I'm putting in 4.10's and a hardend shaft. So we'll see.
Quick Reply: Cartek 2x dyno
