Top speed issue
Top speed issue
I recently replaced my 2002 V6 camaro with a 2000 z28. Early this morning I finally got a chance to drive it fast. However, at about 115mph, 4k Rpm in 5th gear the car just started jumping back and forth kinda like a car trying to take off with someone who doesn't know how to drive standard. I took my foot off the gas pedal and slowed down and it worked fine, but as soon as I tried it again, the same problem occurred. What is this? Any help would be much appreciated. Thanks.
It can be programmed out of the PCM, even the handheld programers will do it. Believe the cars with Z rated tires were limited at something like 160?
where would I go to get this done properly? I mean i've heard stories of people messing with their car's electronics with some horrible results. Like I don't want my car to not idle or to get like 5 MPG. Would a chevy dealership be able to fix this for me?
Yeah, dealer can do it, but probably wouldn't unless you know somebody there. Just removing the speed limiter won't affect anything else. Look for a shop that does dyno tuning in your area, usually a minimum 1 hour shop charge around here.
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
you said in 5th gear....if you have a 6spd...you should have the 162 limiter...if youre refering to OD then its just the governor kicking in...some z28's with 235 tires came with a limiter of 115.
Originally Posted by Hoose
Thanks a lot guys, I really appreciate all the help. I'm gonna look into finding someone to do it for me, I'd probably **** it up.
You'll need to go to a speed shop or get a handheld programmer. Something like LS1 edit can also do it, but it can be complicated to do yourself.
Originally Posted by 1LoudTA
tires exploding my *** i did 135 in my iroc with some H rated BALD tires. i think they were rated at 90mph or somethin. its good to be young and dumb
And BOOM going 150+ will really ruin your day (or your life)
anyone with hptuners can do this. it is as simple as just entering 160 in the box instead of 115. Would take 2 minutes max. VERY SIMPLE. Just go into the regional forum and see if there is anyone willing to help ya for a few bucks or a 12 pack. I'd help ya if i could edit a 2000 and if you lived near wichita...
If you got away with it, hooray. But it doesn't mean every tyre out there will be safe and work at speeds above that which they are rated at.
