Nitrous Oxide - 50 shot?
goodrich969
03-19-2006, 08:15 AM
could a lt1 with 99,xxx on it runa 50 shot of nitrous safely if it was completely stock?
goodrich969
03-19-2006, 08:28 AM
when u say "id step the plugs closer" what exactly do u mean, thanks alot man
1MEANGTO
I would surely think so. as long as you change the oil regualarly. I'd step the plugs closer. i have freinds that spray ls1's with 175,000 miles on them.i'd say a 100 or 150 would be safe with the right plugs. Not sure which plugs the lt1 guys use for n2o though.
goodrich969
03-19-2006, 08:29 AM
what do u mean step the plugs closer
227Hawk
I would make sure the fuel pump was up to the job.And then knowing me i'd spray more. :jest:
Hawk :devil:
goodrich969
03-19-2006, 08:31 AM
thanks
1meangto, what do u mean when u say step the plugs closer?
2001z
03-19-2006, 08:32 AM
Hawk :devil:
:jest: that is always the case even more when you start off small like that . Soon enough you will be on the 150 jets thinking will it hold and can i get bigger :)
wdpryor
03-19-2006, 08:37 AM
I'm pretty sure he's talking about the gap on the spark plugs. Stock is .060 or something close to that I think. I gap mine at .038.
goodrich969
03-19-2006, 10:27 AM
how do i get a close gap. buy new spark plugs?
brad8266
03-19-2006, 10:33 AM
You would want to install a colder heat range plug as well as close the gap of it to around .038. You do this with a plug gapper tool that is like 1$ at autozone.
goodrich969
how would i close it? so get new plugs? what brand and kind would u recommend
brad8266
03-19-2006, 10:39 AM
not sure for an lt1 but the ls1's use ngk tr6's.
227Hawk
03-19-2006, 10:46 AM
You need to buy a 1step colder heat range copper ground strap sparkplug.
NGK is the most popular brand for spray. The Parts house can tell you the
plug number. Also buy a sparkplug gapping tool. It's cheap to buy and pretty easy to use. You bend the ground strap on the plug GENTLY or tap it down GENTLY to close the gap to in your case i'd suggest .044 as a starting point.
Hawk :devil:
goodrich969
03-19-2006, 01:23 PM
ok some closer gap plugs. what type of fuel pump, shouldnt i be okay with a stock pump on only a 50 shot, also.. tune?
brad8266
03-19-2006, 06:22 PM
no tuning and with a 50 shot the stock fuel system should be ok
1MEANGTO
03-19-2006, 08:43 PM
you got it. Sorry had a little to drink last night. Head still hurts so I've been staying away from the computer. ! heat range colder not sure on the lt1's sorry.
c4hybrid2007
03-19-2006, 11:47 PM
Make sure your fuel pump is up to task (like stated above), fuel filter, colder plugs, and maybe even a new set of injectors (or have the stock ones cleaned). These would be very good precautionary measures. If you can do the work yourself it should cost you about 300 bucks total ( if you just have the injectors cleaned, and dont buy a new pair). I suggest the injectors because i figure which such a small shot you will be going with a dry shot(safer) but if you go wet you should be fine w/o them.
goodrich969
03-20-2006, 05:37 AM
why would a 50 dry shot instead o a 50 wet shot be safer, i believe its a wet shot
Taubr Unit
04-01-2006, 12:34 AM
you can be safe and run a 150 shot all day long. ChiTown racing by me was tryin to blow there lt1 up on purpose and ran a 400 shot all last year and never blew the motor!! A few of my buddys are runnin 150's all day long with no problems. So a 50 shot you say..... i would spray a 50 shot from every light i left!! But thats just meeeeeeeeee, haha
Manny Fresh
04-05-2006, 03:14 AM
I dont have NOZ yet but i've been doing alot of research on it. From what I read U can use a little over a 100 shot and still be safe on a stock engine as long as u get all the proper stuff on a kit. U should read the "sticky" it well tell u every thing u need 2 know about noz it helped me out a hole lot
Camaro94SS
04-05-2006, 11:04 AM
Get a 150shot wet....if you want to upgrade, a wet is a lot easier...and no one likes jetting anyway, just get a wet with a new fuel pump kit...i beleive LT1 can use TR6 plugs too...atleast thast what i plan on getting...lol
mrr23
04-05-2006, 08:33 PM
back when i had my 94 z28 years ago, it had 89K on it. i put the nos05176 125 dry kit on it. NA it went 13.60. on the kit it went 12.24 @ 113.90. with stock fuel system on it. car had 2.73 gears as well.
Camaro94SS
04-05-2006, 09:46 PM
Wow...thats awesome...so you think my 150wet shot will get me in the 11's?
mrr23
04-05-2006, 09:47 PM
if everything is done right, sure.
