Fueling & Injection - Fuel Rails: Tell me about them.
99FormulaWs6
03-19-2006, 07:12 PM
I'm wanting to put a set of Fuel Rails on my car, I know there are a couple of companies that make them. Some say you need adaptors, etc. What is needed? Are there any that come ready to bolt on an LS1? I know there is:
LS1Speed
Aeromotive
Nasty
Any others?
davered00ss
03-19-2006, 07:15 PM
FAST also makes fuel rails. They do need about $150 in fittings.
Argon Z
03-19-2006, 07:30 PM
http://www.thunderracing.com/catalog/?action=vshop&vid=3&pcid=238
kinsler has rails also. Thunder racing sells them
227Hawk
03-19-2006, 08:39 PM
LS1Speed
Aeromotive
Nasty
Any others?
Factory, powder coated :)
http://i24.photobucket.com/albums/c18/227HAWK/HPIM0482.jpg
Hawk
1QUIKWS6
03-20-2006, 04:01 AM
Sad but true - most of the time the fittings/SS hose runs the same price, if not more than, the rails themselves. :eyes:
Nate @ Nasty Performance has a nice complete fitting/hose kit to go direct from your stock metal lines.
Nasty N8
03-20-2006, 12:21 PM
We have a complete kit fititngs and lines all you will need to bolt them on your car $319.99
nate
99FormulaWs6
03-20-2006, 08:21 PM
Do you have a closer picture of what your rails look like? What colors can you get on them?
PREDATOR95
03-21-2006, 12:06 AM
Has anyone dealt with the trick flow fuel rails. Will these be a direct fit.
Nasty N8
They are polished but I can powder coat them any color you want.
Nate
99FormulaWs6
03-21-2006, 12:23 AM
How much extra to powder coat? Will these affect my mileage, not that it really matters, at this point just curious.
mvonada
03-21-2006, 07:08 AM
Nate you're on it, I like a vendor who is there, thanks!
badass 2002 z28
03-21-2006, 07:16 AM
Not trying to hijack the thread...but what's the limitation on the stock rails?
Nasty N8
03-21-2006, 02:17 PM
Stock rails will feed about 600rwhp. These rails will not change milage. and most colors to coat are $15
Nate
Aaron's 00 TA
03-23-2006, 01:10 AM
Why should I buy one over the other?
1QUIKWS6
03-23-2006, 05:42 AM
They are all pretty much similar in design and I think all use the same internal fuel passage diameter. So your choice pretty much depends on price, and finish options available that are what you want...
sebss
03-24-2006, 08:33 PM
I went with the Fast Rails, I had no idea that the fittings and hoses would run approx $150 as davered00ss mentioned. If you know someone with left over #6 and #8 braided lines you can save a little since they only sell it by the 3ft sections. you'll only need 8 inches of each.
CompTA
03-24-2006, 08:50 PM
FAST rails here...
http://www.awib.us/images/taengine1.jpg
dnm12
03-24-2006, 09:19 PM
this maybe a dumb question and sorry to hijack but can you gety a fuel pressure gauge on stock fuel rail or do the braided steel line on stock rails?
Michael02hawk
03-26-2006, 08:52 AM
I just purchased the fuel rail kit & install kit from LS1 Speed.
Everything bolted on okay enough, and I got all the braided lines/fittings assembled.
My question is tho, the end of the fuel rail, on the pass side/front.
The end of that rail kicks up right behind where the bracket is for the Throttle cable & Cruise control cable.
I was supplied a plug, which would 'barely' make the whole thing fit in that area.
But if I wanted to (and I do), attach a fuel pressure gauge, and other kind of fitting would interfere with that bracket.
Any tips?
1QUIKWS6
03-26-2006, 11:55 AM
Never heard of anyone having that problem? If you look up to CompTA's FAST fuel rails you can see that he has a FPG installed using a straight fitting and it clears the bracket. I want to use a 90 deg fitting so the FPG can be read from the side of the car.
Unless the LS1Speed rails are different? Allthough I can't see how they could be to far different as they still have to line up with the manifold mounting points and the injectors?
CompTA
03-26-2006, 12:17 PM
Some gauges will not clear the area...and mine is actually pretty close. We tried one or two different ones before we got that one to fit properly.
FAST should be selling the gauge that you see in my picture and also the install kit for the rails very soon. I suggest giving them a call sometime this week and asking. I'm not sure if or when it will be available, as I'm not on the sales side of things. :)
Michael02hawk
03-26-2006, 12:30 PM
The LS1 rails line up okay enough with the fuel injectors and 4 bolt points, no problem.
But I think the rail itself, is just longer enough (longer than stock) where it comes so very close up behind the bracket.
In CompTA's, it looks like his rail is actually more towards to outer edge, and clearing the bracket easier.
Maybe I can modify the bracket to get some more room, for right now, there is no way I could get a straight adaptor in there.
sebss
03-27-2006, 07:44 AM
if you look at my pics I used a I used a fitting that allows you to view from anywhere on the car- its facing up. This setup would allow you the option to mount a larger guage and clear the throttle cable.
