TNT ring ?
TNT ring question
is the rubber o-ring that is installed on the ring supposed to be able to go over the throttlebody ot just butt up against it? i'd have to grind a little off the lip of the throttlebody in order to get the rubber o-ring OVER the TB.
Originally Posted by Jake the SSnake
It should butt up against it.
SlowPoke, I had to grind down the lip on my throttle body a little and did it at a little of an angle too to get it on, that and some astroglide or ky or some lubricant of the sort and you should be able to get it, may still take a bit of force, but keep at it, you'll get it.
Originally Posted by slowpoke96z28
i'm surprised the dude from TNT that posts on this board hasnt chimed in.
