Suspension & Brakes - Z28 road racing project
mitchntx
03-20-2006, 09:19 PM
Drivetrain is in
http://www.vilipend.com/~frrax/albums/CMC-8/CMC8_EngCompartment.jpg
Cage is about 1/2 way completed
http://www.vilipend.com/~frrax/albums/CMC-8/CMC8_cage2.jpg
Paint is in really good shape
http://www.vilipend.com/~frrax/albums/CMC-8/Img_0687.jpg
And finally, thanks UMI Performance
http://www.vilipend.com/~frrax/albums/CMC-8/CMC8_UMI.jpg
It should see a podium finish April 21/22 at Motorsports Ranch in Cresson, Texas.
HeapaShifter
03-20-2006, 09:59 PM
lookin' good
Is the engine rebuilt? How much HP & TQ? I know a lot isn't needed for road racing. I'm sorry if I missed a previous post.
mitchntx
03-20-2006, 10:08 PM
Built for Camaro/Mustang Challenge series.
It's a spec series. Limited to 230hp/300tq and a minimum of 3200lbs.
So, the motor is bone stock and has to run a restrictor plate to bring the power DOWN to those levels.
Sounds crazy, I know, but it makes for great racing. And the equipment lasts forever.
DONAIMIAN
03-21-2006, 12:17 AM
Looks awesome, let me know when you plan to run a race at MSRH or TWS.
UMI Performance
03-21-2006, 07:26 AM
Looking excellent Mitch! I am anxious to see it in action :)
VipZ28
03-21-2006, 10:48 AM
Have we found a tubular Kmember up to the task of AutoX/RR duty yet?
qwikz28
03-21-2006, 11:08 AM
what kind of springs are you gonna run?
DONAIMIAN
03-21-2006, 11:12 AM
nope :( but even if it was most of us wouldnt be too excited about changing it out for the small gains we would get.
VipZ28
03-21-2006, 11:15 AM
:( weight off the front end is weight off the front end... What about a-arms?
DONAIMIAN
03-21-2006, 11:54 AM
Yea, people have been using the LG stuff up front for a while, but after reading on how much of a PITA it was to install the lower arms, I didnt care for them anymore. That and the fact that I cant see a gain anywhere else besides weight reduction by going with the uppers, least not for me specificly.
mitchntx
03-21-2006, 12:18 PM
Since we are building these cars for competition, it wouldn't be prudent to give my competitors baseline knowledge of the car's setup.
Not to be an ass, just trying to keep a competitive edge.
qwikz28
03-21-2006, 07:39 PM
lol true, no offense taken... just curious cause i'm turning my car into a weekend road course car. just trying to see what the pros use. good luck this year
Glenn98ZM6
03-21-2006, 08:42 PM
w/ all the failures of these things on the street i bet money none of them would last a weekend on the road course. not worth 10 times the weight reduction you see w/ one.
Glenn98ZM6
03-21-2006, 08:50 PM
LG's fronts are for camber/caster gains not weight reduction. when you need 2.5 degrees camber on a street car, they are what you need to do it.
Glenn98ZM6
03-21-2006, 08:59 PM
dont go calling us Pro's. we are weekend worriors just like most everyone.
you need to give more info though. track only car or daily driver?
650 175's would be close. but that aint what we are running. i dont think ou got the sack to run what Mitch runs. :eek2:
Ojustracing
03-21-2006, 09:10 PM
Mitch arent you using springs from the M1 tank.
Looking good
John
Rescue Ranger
03-21-2006, 09:14 PM
that car looks like it'll be so much fun
mitchntx
03-21-2006, 09:15 PM
Dammit, John ...
Glenn98ZM6
03-21-2006, 09:25 PM
FYI, class minimum weight for 4th gens is 3200lbs w/ driver post race. my last race weekend i crossed the scales @ 3202 w/ half a tank of fuel. we are limited as to what we can cut/remove, so thats a very light car w/ an LT1. i weigh in @ 220. i bet its under 2950 dry.
qwikz28
03-21-2006, 11:00 PM
i'm a noob so as far as i'm considered you guys are pros. thanks for the spring specs. sounds good to me
DONAIMIAN
03-22-2006, 12:29 AM
I used the wrong words in that post
I meant as to how my car is set up now, weight reduction would be the only gain/bennifit that I would see out of them. Im happy with my current alignment right now, I couldnt imagine running that much camber on the street, im already upset about the wear with the -1.0* I have now.
mitchntx
03-22-2006, 09:24 AM
Your rate will depend a LOT on the sway bar combo you can use. The bigger the bar(s), the less rate you can run.
You want to run as soft of a spring as you can that will do the job.
qwikz28
03-22-2006, 09:32 AM
wow theres alot more to suspension choices then i thought. i'll have to do more research. thanks
