94 Z28 suggestions
air is easy to rmove just remove the whole pump itsfelf plug up the intake pipe, and if you have a good air fuse you wont have any ses lights, but there is no point in removing it if you are running manifolds.
As I understand it, removing the EGR is supposed to throw the SES in a 94, so I left mine hooked up. I did however disconnect the A.I.R. setup w/ no codes or problems, but that was mainly because I broke the stock tubes trying to remove them from the manifolds during my header swap.
You're not going to gain any power by removing either though, removing the AIR system will clean up the underhood area a little but that's about the only real benefit you're going to get...
My egr is also gone with no light, no power gain either. Just wanted it out of the way.
