what fuel system upgrade is needed for a 75 dry shot?
i'm switching out my 26.2 lb injectors to 28 lb injectors from a stock 02 Z.
what else is needed in the fuel system to safely spray a 75 dry? or is it safe stock? injectors necessary? plugs?
-Brian
-Brian
If you are stock (or bolt ons) mod wise you'll be fine on a 75 shot with the stock injectors.
Matt
Matt
-Brian
-Brian
You'll want to run the TR6s no matter what size shot you go with. Chances are you'll be okay on the 100, on the 125 you might want to start logging injector duty cycle to see where you are at, figure you'll be around 470 ish rwhp on a 125 shot.
Matt
Matt
