Generation IV Internal Engine - LS6 and L92 heads side by side
View Full Version : LS6 and L92 heads side by side
StreetnStrip
03-21-2006, 06:20 PM
Look at how similar they are the only difference by looks is the intake ports. Its sucks becaus eall I need is an intake and I could be running or I could get a sheet metal one made but I really want to keep my stock look. U guys got any suggestions?
http://www.streetnstrip.org/forums/attachment.php?attachmentid=1928
http://www.streetnstrip.org/forums/attachment.php?attachmentid=1924
http://www.streetnstrip.org/forums/attachment.php?attachmentid=1925
http://www.streetnstrip.org/forums/attachment.php?attachmentid=1927
http://www.streetnstrip.org/forums/attachment.php?attachmentid=1926
Steve Bryant
03-21-2006, 06:58 PM
Keep looking for the Holden P/N. I'm sure that you'll be able to get an intake by mid summer.
Steve
StreetnStrip
03-21-2006, 07:06 PM
i was thinking of maybe tryin an LS1 intake just to see what happens
NemeSS
thanx 4 da pics
i was hoping to adapt a gm single plane since their ports are more
rectangle shape than cathedral
StreetnStrip
03-21-2006, 07:07 PM
thanx 4 da pics
rectangle shape than cathedralu got any pics of the ports?
JZ'sTA
03-21-2006, 07:22 PM
Good luck.
Nice pics though.
At first glance I was like "damn what are those heads sitting on to stay in the air?" Then I realized the picture was turned sideways and the heads were on top of eachother and on the ground. :eyes:
jrp
03-21-2006, 08:53 PM
combustion chambers are different too.
StreetnStrip
03-21-2006, 08:57 PM
combustion chambers are different too.yeah there 71cc i believe and these heads will only work with a 4.00 or bigger bore.
jrp
03-21-2006, 09:05 PM
i meant the shapes, the L92's are more kidney shaped.
Richard@WCCH
03-21-2006, 09:12 PM
Maybe an Edelbrock Victor Jr. could be modified to fit. It would take filling the floor and raising the roof to get it done. Just a thought.................
Richard :)
JZ'sTA
03-21-2006, 09:18 PM
Richard :)
I haven't seen this intake in person in a few months but you might be right.
I bet someone like TEA could work on something like that for you.
The have raised the floor on a few sets of heads.
Worth a shot.
JBT
03-22-2006, 01:18 AM
Can you buy the truck intake for the l92 now?
StreetnStrip
03-22-2006, 02:47 AM
yes u can
JBT
03-22-2006, 06:56 AM
yes u can
part number?
LS2Monte
03-22-2006, 07:15 AM
Not to hijack your thread but...I'm guessing the heads are for sale now? I know the number works in GM parts direct but didnt know if you could actually use them.
Thanks
Nick
'88SS
slt200mph
03-22-2006, 07:50 AM
to the top
StreetnStrip
03-22-2006, 10:05 AM
Thanks
Nick
'88SSyes they are for sale i got mine about a month ago.
bigredexpress99
03-22-2006, 01:46 PM
12580678 - l92 truck intake p/n...... :)
MrDude_1
03-22-2006, 02:28 PM
thank you... ive been looking for that.
any pics of the intake?
any chance of us getting the exploded view of it, with part numbers?? because we'll need the matching rails and such.....
btw, do standard injectors fit in it?
is there a GM part number for the intake manifold assembly (rails, injectors, ect...)??
gun5l1ng3r
03-22-2006, 06:13 PM
One other thing... Do the rectangle ports really offer an improvement over the cathedral port? If not, then what makes the L92 such a desirable head?
2c5s
03-22-2006, 06:26 PM
I have a price coming for the aussie car intake, I should have it on Friday.
StreetnStrip
03-22-2006, 06:35 PM
One other thing... Do the rectangle ports really offer an improvement over the cathedral port? If not, then what makes the L92 such a desirable head?the 2.16 intake valves is what kickass and so does the flow numbers compaired to a set of aftermarket heads that cost around 2000 for a good set. these heads cost 400 for a set but there bare. With a good set of aftermarket springs and the GM valves I bet u could be in these heads for around 800 complete.
FAST LS1
03-22-2006, 08:17 PM
I've tracked the LS2 402 shortblock fpor months with hopes of doing that swap along with AFR heads. Now this L92 head seems like a much better option, along with the larger bore short block. I hope you guys figure out the intake problem so we can all start doing this swap more easily. I think this will be the most cost effective swap in the coming year if an intake can be had to work on our cars.
stang90gt50
03-22-2006, 10:31 PM
Hmmmm so the only thing keeping all of us from running the L92 heads is an intake.
Will the LS7 intake bolt up to them?
Richard@WCCH
03-23-2006, 12:01 AM
Doesn't look likely. The L92 bolt holes are in the same location as the LS6 heads. The LS7 bolt holes are higher up the intake flange. Now, if there's some extra material to drill and tap holes for the LS7 intake...........
Richard :)
MrDude_1
03-23-2006, 07:37 AM
the answer is no.
the ports are different.
the bolt holes are different.
there is not enough material to make up for the differences.
currently the only production intakes that fit:
the 2007 L92 Truck intake
the 07 holden intake (not stocked or currently sold in the US)
slt200mph
03-23-2006, 07:47 AM
Cause they flow like a mofo and are low in cost compared to the aftermarket heads that cost an arm and a leg.. :)
stang90gt50
03-23-2006, 09:56 AM
Heres some pics of the L92 intake and engine
http://www.autoblog.com/2006/02/21/gms-l92-and-ls2-v8-engines/
http://www.4wheeloffroad.com/featuredvehicles/0510tr_07tahoe/
JBT
03-23-2006, 10:20 AM
Maybe it would be a god idea to post a sticky with the necessarry part numbers to run l92 heads. Some pn# to start with.
Heads (bare) #12582714
Truck intake #12580678
Holden intake #?
Fuel rail #?
Throttle body #?
Intake valve #?
Exhaust valve #?
Rocker arm #?
MrDude_1
03-23-2006, 10:40 AM
Holden intake #?
Fuel rail #?
Throttle body #?
Intake valve #?
Exhaust valve #?
Rocker arm #?
really, we need a whole FAQ on it... including that.
EVERY SINGLE THREAD is full of the same questions.. some we have answers to, others we dont.
example:
Does the LS7 intake fit?? NO the LS7 intake does not fit.
do i need a new rocker arm locator strip?? we dont know yet, but very likely since the intake rocker has been moved.
StreetnStrip
03-23-2006, 11:28 AM
example:
got any pics of the intake?
MrDude_1
03-23-2006, 12:11 PM
witch intake and what do you want to see? :)
NemeSS
03-23-2006, 03:29 PM
tru dat! :)
gun5l1ng3r
03-23-2006, 03:42 PM
I would really like to see a cutaway pic of the truck L92 manifold.
Big-DEN
03-23-2006, 04:04 PM
gun5I1ng3r,
Remember the "cathedral" portion of the port was simply for the fuel injector to be
able to shoot toward the back of the intake valve and be as close as possible to it,
it is not there for air to travel.
That L92 head is awesome, look how much the port is raised over the LS6...
StreetnStrip
03-23-2006, 05:27 PM
witch intake and what do you want to see? :)I would like to see the pic of the new 07 tahoe intake
corvettetimmy
03-24-2006, 02:58 PM
I managed to get ahold of 2 ls7 intakes new in the box
they are both for sale.
500 each plus shipping.
pm me
StreetnStrip
03-24-2006, 03:10 PM
pm meTHE LS7 INTAKE WONT WORK
427
03-24-2006, 04:00 PM
The guide bar for the rockers is L92 only, it has a slightly different spacing.
Kurt
stang90gt50
03-24-2006, 05:44 PM
Well I guess what we all really are wanting to know is if a Victor intake can be modified to fit it.
StreetnStrip
03-24-2006, 05:47 PM
Well I guess what we all really are wanting to know is if a Victor intake can be modified to fit it.I got one on the way hopefuly it will work for us.
StreetnStrip
03-24-2006, 05:48 PM
KurtAs long as we have the guide rail we can use the LS1 or LS7 style rockers?
Nate_Taufer
04-06-2006, 12:46 AM
Pretty sure you use the LS7 rocker because the intake is an offset rocker.
Nate
BLKWS6
04-06-2006, 11:27 AM
does anybody know if the MLS gaskets from gm would work with the L92 heads? looks like the coolant ports are the same from the pics....kinda hard to tell though...
gollum
04-06-2006, 11:53 AM
Can you post some close up pictures of the ports and combustion chambers?
MrDude_1
04-06-2006, 12:30 PM
from what i looked at, the 6.0L gaskets will work just fine with them.
of course, my engine isnt together yet to know for sure, but everything seems to line up just fine..
BLKWS6
04-06-2006, 12:47 PM
other than being designed for the larger bore...any reason (physically) these wouldnt work on a LS1/6 block?
MrDude_1
04-06-2006, 01:37 PM
if you weld up the chambers and the valve seat area, machine the deck flat again and recut the valve seats for smaller valves so it fits in the bore.... yea they'll fit on there and work.
sounds like alot of work, but thats what i intended on doing, right up until i started pricing 6.0L shortblocks.... it would be cheaper for me to buy a stock shortblock then it is for me to modify the heads for the LS1.. but if i could weld and machine them myself, the opposite would be true.
