Need Some Help
Need Some Help
I am in the process of upgrading my 02 Z28 with either a 12 bolt or 9" Moser(if i can ever decide)
i am wondering if when i upgrade the rear with the 1350 yoke....will i also need to get a new driveshaft or make any modifications to my stock one?
i have heard different things from different people so i was hoping that someone could give me a hand.
please let me know what you think
You can just go to NAPA and by the cross-over U-joint to match up the stock shaft--which you can use with a 9 in. I did that with mine. Pretty sure it's the same with a 12 bolt. Do a search to find the PN you need. That's all there is to it as far as mating the rear to the drive shaft. If you have the power to justify a heavy duty rear and plan on drag racing with sticky tires, you might plan to upgrade to a stronger drive shaft before you race. Good luck with it.
