What series carrier is my rearend?
Old 03-21-2006, 08:53 PM
smkeater911's Avatar
Default What series carrier is my rearend?
I have a 98 camaro Z28. Where do I look to see what series carrier my rearend is? I wanna put 373 in. What is everyone opinion on Motive gears? Ive seen that some are thicker than others whats the difference?
Old 03-21-2006, 08:59 PM
227Hawk's Avatar
It'll help if you tell us whether you have 2.73 or 3.23 now?
Hawk
Old 03-21-2006, 09:07 PM
Z28LS1camaroguy's Avatar
sticker on the door you will look for the code GU2-2.73 and GU5-3.23 or 3.42, and the thicker gears are for the 2 series carrier (7.5") which is the 2.73 carrier that needs beefier gears and the 3 series carrier (8.5") holds the 3.23s and 3.42s which dont need to be as thick. also might help to put this in the gear section that will help us and you out.
Old 03-21-2006, 09:21 PM
thanks for the info
Old 03-22-2006, 01:16 AM
That's what she said...
TheBlurLS1's Avatar
The reason for the different carriers is that the ring gear needs to be in a different location relative to the pinion gear, as their physical sizes change as the gearing changes, not just the difference in number of teeth.
Old 03-23-2006, 08:49 PM
WILWAXU's Avatar
Great question for the drivetrain section
