New Mods!
Old 03-22-2006, 12:35 AM
whitedevil's Avatar
Default New Mods!
Well, today I ended up installing the following:
1:SLP Loud Mouth
2:SLP Lid, CAI, with K&N, & Bellows
3:SLP three way Sub Frames
4:And Reinforced my LCA's and Panhard rod (welded steel inside)
I have to say that the first test drive after everything was taken care of, blew my mind, what a difference. The subframes make so much of a difference, I suggest it as one of the FIRST mods for anyone new to the F-Body world. I really like the way the LM sounds under WOT.
I am thinking of the PRO 5.0 next, I hate the sloppy shifter in there right now. I am having trouble deciding what I should do next...
Old 03-22-2006, 12:23 PM
JerseyLS1TA's Avatar
shifter like you already said, it made a nice difference when I drove my friends 6-spd fbody before and after the install.
Old 03-22-2006, 12:37 PM
lgobraves's Avatar
if you have a hurst look into putting a short throw shifter on. It helped mine out a lot.
Old 03-22-2006, 03:06 PM
whitedevil's Avatar
I know for sure I do not have the Hurst, I hate this thing, and I hear a lot of ppl rave bout' there PRO 5.0...
Old 03-22-2006, 03:50 PM
SSU, come over and relax
skywalkrNCSU's Avatar
i went with the pro 5.0 with lous short stick and havent looked back
Old 03-22-2006, 04:14 PM
Mike02Z's Avatar
Could not agree more! The stock shifter is just pure torture compared to this combination. Shifts are short and very positive. I used to have an issue shifting hard from 2-3 with the stock shifter and in the 2+ years of having the Pro 5.0 and LSS I have not had even one issue with the 2-3 shift. Awesome combination.
Of course once you get the Pro 5.0 and LSS you'll need SFC's next.
Old 03-22-2006, 10:35 PM
'Trust''s Avatar
Good to hear. Although I doubt the subframes are the differnece your noticing, probably the LCA's and Panhard, those seem to make a good difference, SFC's just stop the frame from twisting.
Old 03-22-2006, 11:33 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Would they stop those creeks im getting when I go over speed bumps, or hit a bump in the road? Sounds like my cars a old man getting off the couch " creek/crack/crunch OH MY BACK "
Old 03-23-2006, 02:32 AM
whitedevil's Avatar
I actually purchased the subframes from a friend for next to nothing BRAND NEW. The difference between the "stock" LCA's and Panhard was huge, I had a friend reinforce them with steel inserts. What a defference! Even with the stock wheels, I can launch a lot better, it holds first beter, and is harder to break the tires loose in second and third.
The subframes were a total B*TCH to get on the car, expected at 60k or more miles, (due to a few rock dents on some of the areas where you "bolt" them in). Either way, so far I am happy with the out come.
