75 dry shot
75 dry shot
if i spray a 75 dry shot, do i have to worry about my engine throwing a rod, bending a rod, cracking/melted pistons or blowing up my vararam cold air intake? i already have full boltons including LTs, catback,vram, 160stat,xpipe,and hp tune. will i have to retune my car the 75 dry shot?
do i also have to descreen my MAF?
As long as everything is in proper working order (colder set of plugs too) you shouldn't have any issues with the 75 dry shot. Usually it's recommend to remove the MAF screen when spraying a dry shot.
Matt
Matt
I have sprayed about 6 bottles into my motor since I have been running a 240 RWHP Dry shot and she held up fine but now the motor has been pulled to go bigger and better and everything looked great. little worn out on the rod bearings and 1 burnt plug but that is normal for a 650+ RWHP stock bottom ls1 If you wanted to stay safe I would say a 125RWHP shot all day with colder plugs and a little richer on the tune (if you want to be real safe) Some say pull some timing and others say 125 there is no need so i guess thats up to you but If your running it rich and you have the plugs I would say let the timing stay how it is.
