drive shaft? 4l60e- th350
Old 03-22-2006, 09:09 AM
chrdij's Avatar
Default drive shaft? 4l60e- th350
I have done some research on the TH350 swap, but most of these swaps are from M6-TH350. I know the drive shaft will fit (off a M6) using a 9" tail housing, but what about a 4l60e-th350? Would the drive shaft fit using the stock one or will I have to use one off a M6?
Old 03-22-2006, 11:57 AM
chrdij's Avatar
take it to the top
Old 03-26-2006, 10:20 PM
chrdij's Avatar
any one at all know if i can use the stock drive shaft off a 4l60e?
Old 03-27-2006, 10:30 AM
1QWIKZ's Avatar
i thought you can use the stock one with a 9" tailshaft
Old 03-27-2006, 10:50 AM
ApacheDrill's Avatar
Yes with a 9" tail you can.. any other size u need to get a custom drive shaft made.. I run a Dennys and it works great
Old 03-27-2006, 11:45 AM
chrdij's Avatar
that is what i needed. Thanks!
Quick Reply: drive shaft? 4l60e- th350
