vibration problems
vibration problems
I just had a turbo 400 and a shortened steel driveshaft put in and at around 3600 to 4500 rpms there is a huge vibration. I have had the driveshaft balanced twice and it's perfect. The only other problem is that the driveshaft has a little play in the tailshaft of the tranny. Could this be the whole problem? Also what is needed to repair. Thanks in advance
Read through this thread, may have to do with Drive Shaft Critical speed.
https://ls1tech.com/forums/conversions-swaps/473265-u-joint-angle-question.html
Hope that helps
Pat
Hope that helps
Pat
