Northwest Members - The Good, The Bad, and The Ugly.
View Full Version : The Good, The Bad, and The Ugly.
Ryan K
03-23-2006, 12:24 AM
The Good:
http://www.highspeedproducts.com/images/comp-R-Lifters-002.jpg
The Bad:
http://www.highspeedproducts.com/images/comp-R-Lifters-003.jpg
The Ugly:
http://www.highspeedproducts.com/images/comp-R-Lifters-004.jpg
From the Producers of "These Comp R Lifters Suck"
Ryan K.
CHarris
03-23-2006, 12:28 AM
Two comments....
1) Damn... the subject material of those pics sucks
2) Have you considered hand modelling?
Seriously... whats the plan now?
Ryan K
03-23-2006, 12:35 AM
Well, I have never had a problem with the Comp R's previously. You guys do realize how much of a PITA changing out Lifters on an LS1 is? I went with OEM replacements from Crane. My cam isn't big enough to warrent a $500 set of lifters. I am under .600 lift and don't spin over 6500 rpm... fingers crossed.
Ryan
TwoFast4Lv
03-23-2006, 01:20 AM
That is Damn ugly! Got me all worried. going to have to look at the Finances and see if I can get soem Morels or Crane High lift :(
Anyone in the market for a set of 600mile Comp "R" lifters?
WAHUSKER
03-23-2006, 07:52 AM
:eek2: DAMN!!! :stupid:
So what was your symptom? Since I'm running a similar setup to yours for lift & rpm level, some of my body parts are suddenly quivering.....did you just start to get a bunch of rocker arm noise, or was it something else?
And as much of a PITA that job is, I'm sure glad you found it before it went :bomb:
Ryan K
03-23-2006, 08:46 AM
Actually it was really odd, the valve train was quiet at idle up to 1700 rpm and 3000 rpm and up. But if the rpm was held constant from 1700-3000 rpm the lifter would bleed down and make noise. I think its hit or miss.
Ryan K.
WAHUSKER
03-23-2006, 09:37 AM
So no loose rocker arms when you pulled the covers, no missing / popping at hi rpms, no power loss above 5k, none of the "normal" signs a lifter is going bad? FRACK!!! :bang:
Rokko
03-23-2006, 10:19 AM
Do you have Comp R's in the stroker?
-PEPE-
03-23-2006, 10:29 AM
Been there done that, when Peppe had stock cubes couple years back with the 847 and 1.7s, she went a good 9 months before eating a CompR. Surprised Comp hasn't redesigned yet.
WAHUSKER
03-23-2006, 11:55 AM
Why yes, I do. But I also have adj rockers, which is rumored to lessen the risk on this issue (or so I thought). Here is a link to the LOOOONG thread on this subject on the Camaro website:
http://web.camaross.com/forums/showthread.php?t=394574&page=8
99blancoSS
03-23-2006, 12:43 PM
hand modeling :jest: spit my orange juice out on that one.
Damn scary lifter pictures though. I've got Comps but not "r" just the oem replacement ones, but still that leaves me :confused:
01T-TopToy
03-23-2006, 07:16 PM
I am sorry to hear of your troubles man, that truly blows :( I had no idea ....
Umm I did have a question, not to hijack the thread, is the rest of Comps stuff an issue ? I did the #54100 valve train set and a Comp Cams cam
54-412-11 (XR265HR) *or something like that ... Should I have em yanked before the engine is in final assembly this week ? :eek2: I went with Crane Lifters simply cause I got a smoking deal on some over stocks... but now I am scared.. I am in way too deep and your pics are giving me cold sweats :cry:
Jon A
03-23-2006, 10:38 PM
A familiar sight....
http://www.jonaadland.com/NewPics4/CompRs1.JPG
01T-TopToy,
I use lots of other Comp stuff without worry. It's just the R lifters I won't touch. Once burned.... To their credit, they replaced mine with a new set. I sold those bastards and put the stock ones back in. :D
TwoFast4Lv
03-23-2006, 10:44 PM
I am getting limited on Comp products I WILL use
-PEPE-
03-23-2006, 11:07 PM
Werd...done with hydraulics though :devil:, Jessell solid rollers going in the new build.
So I wonder who's taking up the CompR slack? Forums everywhere ppl are posting their failures with them.
WAHUSKER
03-24-2006, 08:11 AM
I wish now the Morrels or Jessels would have been available when I was building my motor. Certainly would have been worth an extra $3-400 for the peace of mind!!! :eek2:
TwoFast4Lv
03-24-2006, 08:58 AM
We have lost cams and rockers on a regular Basis and now lifters.
Not much else left ;)
I am a pansy. I am still running a baby HR and have my a/c ;)
-PEPE-
03-24-2006, 09:49 AM
:jest: ya don't need AC in Seattle do ya? Damn sure do in Houston. Well I'm keeping my AC too, SpeedSpecialty has a keep your ps/ac alternator relocation bracket instead, so I can run tall valve covers with shaft mounted Jessels and set my valve lash in under 20 minutes without moving my Alternator every time. I don't want to have a strip only NO AC car ...not yet anyway...
Rokko
03-24-2006, 10:02 AM
which rockers? i hope you don't say pro mags. :(
99blancoSS
03-24-2006, 10:06 AM
question: What cam are you running?
There have been some issues with FM13's and eating lifters that I read about.
Ryan K
03-24-2006, 10:13 AM
My cam is a baby Turbo cam, 226/222 .570" lift on a 115lsa.
Ryan
99blancoSS
03-24-2006, 10:24 AM
Was there any other damage? Is it and Futral cam? I'm semi concerned here. I know I've got a TR cam with less lift but I did use Comp lifters. What told you you had an issue?
Ryan K
03-24-2006, 12:04 PM
Read Post #6
99blancoSS
03-24-2006, 12:50 PM
Is there any way to hold Comp responsible?
-PEPE-
03-24-2006, 05:39 PM
Doubt it, I'm curious if anyones called Comp about this issue with CompR's, camaroz28.com like this forum both have sticky's regarding these POS lifters, imagine surfing a little might turn up what Comp has responded to some folks regarding these.
99blancoSS
03-25-2006, 01:52 PM
ryan are you running a futral cam?
Ryan K
03-25-2006, 03:36 PM
CamMotion
