Tranny options need help
Well heres whats going on im building a 346 heads,cam crank,intake and 175 to 200 shot im now planning my tranny i have a 4l60e with a 4400 vig im trying to figure out if I should build the L60 or go with the th400 for the trans break.Ive found something what else would I need any links to cheaper prices? Ill be selling my set up i have if i go that way.Im going show go with the car and going the custom way. whats the opion of the site on what would be the best to run
Driveshaft
Extreme-Duty Driveshaft - TH400 Short Tail
tem: LMC400
$340.00
Crossmember
27-TCC001 BMR Transmission Conversion Cross Member, TH400 into LS1 F-body $169.95
TCI flexplate
141-399753 TCI Automotive SFI Approved LS1 Flexplate, 1998-2002 LS1 F-body & 1999-up GM Trucks w/ 4.8, 5.3 or 6.0L $199.99
Torque Converter
19-VIGILANTE-NL Vigilante 9.5" Single Disk Torque Converter, PowerGlide, TH350, TH400 $639.99
Driveshaft
tem: LMC400
$340.00
Crossmember
TCI flexplate
Torque Converter
