transmission temp guage
Old 03-23-2006, 09:04 AM
JstALs1's Avatar
Default transmission temp guage
Hope this is in the right forum. Any ways i am going to pick up my trans temp guage today and was wondering, those guys who have them were did you put the sending wire in the trans to pick up the temp? Also will i need anything special to put it in Thanx
Old 03-23-2006, 09:10 AM
jmm98LS1's Avatar
There's a port right above the shifter linkage on the driver's side of the tranny. Remove the bolt in that port and replace it with the sending unit. You'll need some extra wire to hook up the power/ground/lighting.
Old 03-23-2006, 09:14 AM
GregWS6&z28's Avatar
yes, that is it
Old 03-23-2006, 09:19 AM
King James's Avatar
Or you can weld a bung into the pan. Or get the temp gauge manifold from Autometer and install it in one of the cooler lines.
Old 03-23-2006, 09:51 AM
JstALs1's Avatar
cool, thanx guys i plan on installing it later today just wanted to know whats involved. Sounds pretty easy as far as ground and power i was just going to tap into the radios ignition power wire and ground it on the frame as far as the light goes i was going to tap into the light for the gear selection so i can have the dim feature.
Old 03-23-2006, 10:10 AM
King James's Avatar
I take it your not installing it on the pillar by your choice of wiring locations?
Old 03-23-2006, 10:18 AM
sure he could, thats how I did mine. not much wire is needed to reach the radio and dimmer switch
Old 03-23-2006, 11:03 AM
BURN'EM's Avatar
But installing it in the cooler line will Not give accurate temp of trans internals. Use the port above the linkage
Old 03-23-2006, 11:25 AM
King James's Avatar
Explain?
Old 03-23-2006, 11:27 AM
JstALs1's Avatar
yeah im going to install it were that usless holder is next to the cig lighter. I took it out and made up a piece of plastic to go in its place. It looks like stock, ill post up some pics when i get it done. I didnt want to put it on the pillar cuz in my neighborhood they will jack that stuff really fast.
Old 03-23-2006, 11:39 AM
JstALs1's Avatar
there are some pictures in the appearance forum under "post pictures of your guage pod thread."
Old 03-23-2006, 03:25 PM
BURN'EM's Avatar
Explain?
Because the cooler does as it says cools. the futher away from any heat source the cooler a reading will be. Therefore temp sensor in the Trans will give the most accurate temp of the internals because it's the closest.
Old 03-24-2006, 01:09 PM
Kenafin_02TA's Avatar
I'm thinking he meant the lines going from the tranny to the cooler...those cooler lines....not the return lines.
Old 03-24-2006, 03:24 PM
JstALs1's Avatar
Hey guys I got the gauge in and it works great just wondering what temp is normal for these transmissions. I have a 3200 stall and a cooler. I started the car and let it run for 10 min and the gauge was reading like 210 when i shut it off. I also check it with the tech 2 and it said that the fluid was 89 Celsius. So does this mean the gauge is inaccurate?
Old 03-24-2006, 03:46 PM
s346k's Avatar
the cooler probably won't do a whole lot until you get rolling..
Old 03-24-2006, 04:33 PM
Anniversary "Z"'s Avatar
89*C is 192*F Depending upon where you installed the sensor could make up most of that difference (192-210).
I got a question for some of the other guys if there is a similar place (above linkage) on the th-400?
