vibration at 3000 rpm
Old 03-23-2006, 01:17 PM
madmatt97's Avatar
Default vibration at 3000 rpm
I just put a new clutch and pressure plate and had the flywheel turned and put a flywheel spacer on my 1997 lt1 camaro and now im getting a vibration in the clutch when I press it down to shift gears and u can feel it in the floor bord to. Anyone know what it could be?
Old 03-24-2006, 08:15 AM
jyeager's Avatar
I think on LT1s the flywheel is balanced with the crank. Is it possible that in the process of being turned at the machine shop, that they messed up the balance?
I'd also wonder as to the condition of your pilot bearing.
It's also possible that the clutch/PP are not balanced. I'm not really sure why that would lead to vibration only when you release the clutch (that's why I'm wondering about the pilot bearing)
Old 03-25-2006, 05:40 PM
madmatt97's Avatar
I think I might need a new flywheel so bought one to see if thats the problem.
