Fuel Pressure safety switch
what is the normal setting for a fpps? mine came set at 35psi, i know ur supposed to adjust the set screw, how the hell do u know when ur at the right psi? also i have a dry system and was wondering what fitting guys were using and how u get a shrader valve removal tool????????
As for the tool i just used the same one as i use for valve stems on tires. THe fpss just adjust it till what ever your using it to turn off turns off then back it down a hair.
