-3an 90degree fittings
Old 03-23-2006, 10:28 PM
02Vortech's Avatar
Default -3an 90degree fittings
hey guys not matter where i look on the net or in local hydraulic and speed shops i cant -3an 90 degree fittings- im looking to making my kit look like a much cleaner install..... and i was wondering if any of the sponsers carry -3an fittings?
Old 03-23-2006, 10:33 PM
860 Performance's Avatar
I'm not sure if Ive ever seen a -3 90deg fitting.
As an option, check with Dave about having him make you a custom -3 hose with a 90 deg hose end.
Vinny
Old 03-24-2006, 06:24 AM
227Hawk's Avatar
http://store.summitracing.com/egnsea...624+4294906669
Hawk
Old 03-24-2006, 07:28 AM
Matt@HSW's Avatar
Are you looking for 3AN hoses with 90s on them? Or 3AN to NPT fittings? Here is a link for hoses with 3AN 90 degree fittings:
http://www.harrisspeedworks.com/shop...cat=367&page=1
Matt
Old 03-24-2006, 12:41 PM
backrdrunner's Avatar
female to female-
http://store.summitracing.com/defaul...=egnsearch.asp
if you need to turn one of the ends into a male-
they do have a one piece male/female 3an 90 unit but its about $6 more and more restrictive with the type of bend-
good luck...
Old 03-24-2006, 05:49 PM
30thz's Avatar
Just to warn you I had a 90* installed on my bottle and it restricted flow a little.
Old 03-24-2006, 11:36 PM
Dune-LS1's Avatar
If at all possible, avoid 90 degree fittings at all cost. 60 degrees max.
Old 03-26-2006, 09:07 PM
Nitro Dave's Nitrous Outlet's Avatar
WE carry a 3 an 90 swivel fitting. Just like the ones used in the NX maff kit.
WE also carry the -3 hoses with 90 degree ends on them.
Dave
