What Fuel Pump
What Fuel Pump
Mods are in sig. it is a full H/C bolt on car I am adding svo 42# injectors I also have a Walbro 255 inline will this pump be ok for a 80 shot DRY halo kit? If not then what do some of you suggest ,also will I need a regulator? Thanks, Travis
If possiable try to use an intank pump. The inline pump won't net you any more volume as the stock intake will be the limiting factor. You could use a Walbro pump or use a Racetronix kit for a plug and play system.
Matt
Matt
