Chevrolet Camaro 1967-2002 - 1990 5.7l Iroc-z G92
View Full Version : 1990 5.7l Iroc-z G92
Mullett bot
03-24-2006, 06:54 AM
Cars in great shape,non t top car,low miles,what if any problems should I look for when I go look at this car?Are these cars very acceptable to bolt ons?Whats the best bolt ons for it?any info on this is appreciated
badjuju342
03-24-2006, 12:58 PM
Sounds like a good car , the main thing is to check for rust and see if the rear cargo area has been hacked under the carpet for a fuel pump replacement. Some people won't drop the gas tank like you're supposed and cut the floor instead resulting in a nasty patch job. Also , these cars came with a posi but a lot of them are 2:73 great for top end , not so great for the 1/4 mile.
demonspeed
03-24-2006, 01:16 PM
A '90 G92 L98 will be 3.23-geared.
htp://www.thirdgen.org is your best resource.
Mullett bot
03-24-2006, 01:53 PM
thanks for the info fellas
Chaotic Firebird
03-25-2006, 12:27 AM
A 90 IROC is a rare car. Check to see if it has a 1LE rpo code. If it does, then it's super rare. Other then that, check for the usual thirdgen stuff.
N01SS
03-25-2006, 03:43 AM
yea 90's were only in production for half a year...i'm gonna check thirdgen.org real quick...
4213 Iroc coupes, and only 62 1LE's total!
How much does the owner want for it?
91RS
03-25-2006, 10:50 PM
Just usual problems when car shopping, like check the oil to see if it's burnt, check the trans fluid to see if there was oatmeal or something put in it to cover up a problem, fluid leaks, etc.
Another fun fact about the 1990 Camaros, none [available to the public] were actually built in 1990. :rotflmao:
