brand of tranny fluid?
Old 03-25-2006, 01:39 AM
TXZ28LS1's Avatar
Default brand of tranny fluid?
hey guys, what brand of tranny fluid do you guys use that works really good? and also what are the bad ones?
Old 03-25-2006, 02:03 AM
ultraz's Avatar
im in the middle of a TC install, since I dont plan on bringni the tranny down for antoher 20k, im going to get a case of redline, Might as well splurge on the important pieces.
Old 03-25-2006, 02:15 AM
BlackHawk T/A's Avatar
Dexron III.
Old 03-25-2006, 08:58 AM
ss97dml's Avatar
i was told not to use synthetic in our trans,just regular DEX III
Old 03-25-2006, 11:32 AM
camaro2you's Avatar
im running valvoline dextron III.
Old 03-25-2006, 12:08 PM
01ls1lover's Avatar
I put redline full synthetic in and *poof* wear did second gear go?
Old 03-25-2006, 11:29 PM
SmokingWS6's Avatar
Aamco Dextron III from autozone. I change it along with the filter once a year.
Old 03-26-2006, 01:52 AM
TXZ28LS1's Avatar
how is mobil 1 dexron III? what bout royal purple?
Old 03-26-2006, 03:18 AM
Restricted User
Automatics's Avatar
For non synthetic oils, I have recommended for over 10 years now, Mobil dexron III, which is what comes in Aamco's bottles, (repackaged) and is easier to find at Auto Zone, than Mobil is most of the time. Trans-Go uses this oil in all of their test vehicles, using a non synthetic oil. i have not seen any problems with this oil over the years.
Old 03-26-2006, 03:21 AM
Dustin's Avatar
i did not know it was repackaged and i had planned on going with Aamco so that makes me feel a little more comfortable.
Old 03-26-2006, 12:25 PM
TXZ28LS1's Avatar
so aamco stuff is basically mobil 1? i have heard good and bad stuff bout aamco?
Old 03-26-2006, 12:47 PM
dnkynrbk's Avatar
how is castrol dextron 3 hold up
Old 03-26-2006, 12:54 PM
Y2kforgedSS's Avatar
Damn im in the same boat as you 01ls1lover, i lost 2nd gear as well but i think the nitrous ate it up .
Old 03-26-2006, 04:42 PM
Dustin's Avatar
i recently lost 2nd, then 3rd, then 4th. Now the car sits in the driveway till my new tranny comes in.
Old 03-26-2006, 05:16 PM
Travis99LS1's Avatar
So the Mobil dexron III is non synthetic?? Do they make a Synthetic and a non synthetic? Only reason i ask is because i have never seen a non-synthetic Mobil transmission fluid. How much is the Aamco at autozone?
Old 03-26-2006, 05:34 PM
ApacheDrill's Avatar
i lost 1st in my TH350 and was running dextron 3.. this time around using Hurst Power Shot, not sure it makes a difference but my tranny builder wasnt happy with what i used before..
Old 03-26-2006, 11:26 PM
SmokingWS6's Avatar
Nope, its Non synthetic, which is better for our transmissions anyway.
Old 03-27-2006, 02:33 AM
Restricted User
Automatics's Avatar
The Aamco oil I am talking about is non synthetic, and is Mobil dexron III, "not" Mobil One, which is synthetic.
Old 03-28-2006, 12:34 PM
TopFlite's Avatar
Just to check, our trannsmissions take 12qts of oil correct?
Old 03-28-2006, 01:04 PM
12secSS's Avatar
4L60E Capacity (according to GM) is as follows.
Bottom pan removal:
7.9L (8.4 qt) (245-mm converter)
10.8L (11.4 qt) (300-mm converter)
