Ticking noise and a slight miss..Any ideas?
I have a 98 camaro SS and I hear a ticking noise that is definatly not an injector and i have noticed that it has idled rougher in the last few weeks. I also have ruled out an exhaust leak (stock manifolds). Think it could be a rocker arm or a pushrod? BTW..its an A4 so no missed shifts..Where should I start?
Re: Ticking noise and a slight miss..Any ideas?
I would strongly suspect a broken valve spring. Dpn't drive it any more and spend a couple of hours pulling the valve covers to check for a broken spring.
Thanks for all of the replies.. I'll check into it tomorrow. Also i have done the egr mod..could it be leaking and making that noise? Also the car has 63k miles on it with TR55's on one side (the easy side) and stockers on the pass side...Long story on why the pass side never got completed.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TurboNotch:
<strong> Is the check engine light on? It might be a lifter. Just an idea. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No SES light or pending codes either. Anyone else have an idea?
LS1Tech Co-Founder
Can also be a simple exhaust leak or a loose spark plug or a plug with cracked ceramic. Check by running car in the dark and look for arcing wires.
