tranny problem?
tranny problem?
My tranny may be on its way out i dont know? When i come to a stop and take off the tranny starts off in secnd gear and up shifts from there this dosent happen at everytime more or less intermittenly. it like the pcm isnt comanding the tranny to downshift all the way to first when comming to a stop. like i said this dosent happen all the time. could it be a selonoid im not throwing any codes at all. the tranny has not been tuned since i put my stall in 3 months ago. thanks.
Obviously sounds like a tranny issue, but my car never had that exact problem when the transmission went out. It would just slip really badly for 1 second every once in a while and then lock up really hard. Better start saving up for a new one,
I have a 2000 ws6 that had the same problem and they said it was my solenoids that went bad. Since they were already in there I had everything upgraded. If you take your transmission out yourself and give it the shop your labor will be cheper.
good luck
good luck
