Car won't start - Fire in intake Manifold
Old 03-26-2006, 08:16 PM
Y2kHawk05's Avatar
Default Car won't start - Fire in intake Manifold
So here is my problem. After the car sitting for about 1 year - we finally got it back together. Now we are trying to get it started and are experiencing problems. Any suggestions or help will be greatly appreciated.
Here is exactly what we did so everyone can understand.
We pulled the engine. Took the heads off and had a professional clean them & replaced the valve seals. We completely cleaned everything before putting it back together. Followed the instructions on "How to rebuild the LT1 - LT4". After replacing the gas and discovering 2 of the injector connections being in the wrong place we attempted to start it. Here are the symptoms. The car turns over and actually backfires through the throttle body. So we are getting fire, obviously gas and have suspected being 180 off, but took it apart to correct that and here we sit. So, anyone have any suggestions? Please help?
Old 03-27-2006, 08:13 AM
96SCTA's Avatar
You have either your timming messed up some how or you MIss wired opti to plugs. My first guess would be thats whats wrong. Check your Spark plug wiring. pass side--2.4.6.8...driver side 1.3.5.7. Your repair manual will tell u where they go on the opti (its very hard to see when its on the car)
Old 03-27-2006, 09:08 AM
buttermantoast's Avatar
Me and my friend had that problem on his tpi it ended up being a mix between his injectors in wrong place and valves not being set right!!!
Old 03-27-2006, 02:48 PM
30th TA 0219's Avatar
Old 03-27-2006, 06:10 PM
Ru2slo_99's Avatar
The valves could be too tight. I had that happen a while back.
Old 03-27-2006, 06:49 PM
matrik's Avatar
Happened to me once before, had plugs in the wrong order.
Old 03-27-2006, 07:38 PM
luckyou03's Avatar
opti!
Old 03-27-2006, 09:15 PM
blu98ta's Avatar
Dammit I f'ed up the injector plugs?? My bad Jim. Man why dont you got that think running yet? Let me know if there is anything I can do to help
Quick Reply: Car won't start - Fire in intake Manifold
