Drag Racing Tech - LCA offset question
FastBlackTA
03-26-2006, 08:21 PM
I need a set of LCA bushings to offset my LCA's in as far as possible as my W's tires are rubbing on the LCA. I know Billingsley had these, but I can't seem to get a hold of them.
Anybody know of a company that has these in stock? I have use BMR LCA's with the solid rod ends.
Thanks.
skipperbisket
03-26-2006, 08:27 PM
wolfe racecraft uses them with their LCAs, not sure if they sell just the bushing but it would probably be worth calling. are you running 28x10.5Ws? that's a lot of tire...
slowpoke96z28
03-26-2006, 09:00 PM
check also umi. i cant remember if they had them or not. i just checked and they dont. sorry.
http://www.wolferacecraft.com/detail.aspx?ID=823 here is the wolfe racecraft piece.
FastBlackTA
03-26-2006, 10:16 PM
Thanks. It's a lot of tire, but should be good for my new nitrous combo.
skipperbisket
03-26-2006, 10:33 PM
you should be able to hook up on a NON-W tire really but if you're setup for a W then it's always good to have a little more than you'll really need.
gator's 99TA
03-26-2006, 10:53 PM
SJM has a set of killer offset double adj chromoly lcas i just ordered and shiped the same day.
go check them out.
1QuickT-A
03-26-2006, 11:06 PM
I'm gonna have to get some myself cause my 28x10.5 non W's are about a half inch away from rubbing and I plan to go with a 325/50 MT DR so I'm gonna need the offset lca's.. Hopefully that will be enough to squeeze the bitches in there...
skipperbisket
03-26-2006, 11:33 PM
the offsets from wolfe move the arm about .75"-1" inside. i'll measure mine in the morning and post exactly what the difference is.
1QuickT-A
03-27-2006, 01:40 AM
That would be great man! Thanks..
gator's 99TA
03-27-2006, 06:13 AM
+1 on measuring. that would be great!
JRracing
03-28-2006, 12:07 AM
I just put my sphoon adj rod end, LCA's on my car. And the have an offset spacer like what your after. It looks to be about 1" offset.
skipperbisket
03-28-2006, 12:39 AM
.807" offset to the inside according to my digital caliper. hope that helps guys
DAPSUPRSLO
03-28-2006, 06:49 AM
Are the bmr pieces tubular? I have the spohn tubular with rod ends adjustable and 315/60/15 et radials which are .4" wider then the 325/50/15 radial according to MT's website and don't have any issues with hitting my lcas.
FastBlackTA
03-28-2006, 03:48 PM
Thanks, but I wasn't looking for tire info :eyes:
Back to the issue at hand - I called wolfe and SJM and it looks like they have what I need. Thanks guys.
1QuickT-A
03-28-2006, 05:56 PM
Awesome man.. thanks for the info!
