help with spec to shim or not to shim?
Old 03-26-2006, 09:53 PM
Blackss99's Avatar
Default help with spec to shim or not to shim?
Hi guys,
I have a spec clutch kit and flywheel it comes with a shim but I think you're only suppose to use the shim if you are using a resurfaced flywheel chime in please.
Old 03-26-2006, 11:26 PM
CW00BlackTA's Avatar
Either way... use the shim.
Old 03-27-2006, 12:30 AM
DONAIMIAN's Avatar
I agree
Old 03-27-2006, 10:13 AM
black01_WS6's Avatar
yup use the shim
Old 03-27-2006, 10:36 AM
maxf's Avatar
Shim for the win.
Old 03-27-2006, 10:52 AM
HASTINGSRJ's Avatar
Definatly use the shim.....
Old 03-27-2006, 04:01 PM
Orange99Z's Avatar
I used the shim the first time The second time the clutch slipped so I had to pull the tranny to remove it. That fixed the problem. Use the shim.
