car shifts at 6500 rpm
I just car a cam (224/230) and a 3200 stall,
the car was tuned by they were having some issues with the dyno, so I have to have it retuned,
well, on my way home I floored it from 60mph to 100mph, and the car downshifted fine, but it didn't shift until what looked like 6400-6500 rpms, it didn't hit the rev limiter even floored all the way,
but is that a safe point for it to shift?
I remember it shifteing at 6000 rmps stock.
pat
pat
Do you have an aftermarket tach? If not you stock tach is inaccurate and slow (so is every stock f body tach). The tranny is shifting before that rpm in real time. I sometimes see 7000 on my stock tach.
I never heard about that, but that makes me feel better,
I didn't think it should be allowed to shift that high,
but what about the fact that the tach showed 6000 shifts before,
could it be because of the stall?
pat
you said this started after your cam install. The cam you have installed should put you at around a 7k redline. I haven't heard of stock tach's being inaccurate but it may be true, or it's normal for your car to shift at 6500 rpms with the pedal to the floor. Put it it nuetral and mash the pedal to see at which rpm it starts bouncing off the redline. I have an m6, but hope the advice helps.
good luck pat
I pity my neighbors' ears as well
It shouldn't hurt your car to redline in nuetral because there is no load.
Also let the rpms drop and then punch it again to see how responsive your tach is, compared to actual throttle position and rpms.
Best of luck
Best of luck
Better than redlining in drive, No? Like i said I have an m6, but am sure that redlining when going through driveline is a lot worse.
The engine is under least stress when idle(m6) because it's not going through clutch, ds, rear. Wouldn't the same be accurate for an a4 car, not having to go through tq.conver.,ds,rear. It's not going to flood the engine in a 2 minute nuetral test.
Can you state your reasons or advice for the post, Travis?
When it was tuned, didn't thay change your shift points up? Adding a cam and stall you should not be shifting at stock shift points, you should be shifting around peak HP now.
My tach reads slower than what my actual RPMs are, for example, at WOT 6800 RPM will read more like 6200 RPM.
Dan
Dan
I see what you mean travis, didn't think about all of the power having nowhere to go except rotating around.(stuck in limbo)ha
It's hard as hard to explain as comparing an a4 with m6.
When tuned, Pat's shiftpoints should have been set, but if he doesn't know his redline then wouldn't the nuetral test be the safest before having to pay $??His shop should have given him a dyno chart to show peak hp. Shifting above the peak hp would not be optimal, but maybe normal with an a4 with the pedal mashed.
good explanation trav.
