BlackHawk02
03-27-2006, 10:01 PM
Has anyone replaced one? If so how difficult was it and can I use any ball joint separator or do I need to use the specific tool mentioned in the manual?
2001 Corvette Convertable
terry s
03-28-2006, 10:53 PM
If you use a wedge style (pickle fork) to separate the ball joint you will ruin the rubber boot. Check with your local auto store & see if they loan tools. I know Auto Zone does. I was in Auto Zone today and they had a picture of all the tools they loan on the counter. I believe O-Reilly does also. I think you pay for the tool (in case you keep it) and they give your money back when you return the tool. They should have a ball joint separator that will not damage the boot.
I have not done one but if you have the factory manual it should guide you. If you don't have one let me know. I have an 02 manual I could fax the pages to you. I imagine it would be the same as your 01. :)
usd2sing
04-06-2006, 10:29 PM
http://www.jakelatham.com/C5/misc/C5_Rear_Wheel_Bearing.doc
i used this write up. first one took 3hrs 1 of which was spent driving around looking for a 55tqx.
other side took 1.5hrs.
