View Full Version : LT1 Brakes
joshua32
03-28-2006, 10:46 AM
Does anyone know where I can find a good write up for changing the rotors and pads on an LT1? I haven't started to work on it but was planning this weekend and just wanted to be prepaired. I also used the search and didn't really find anything.
Thanks
Joshua
joshua32
03-28-2006, 07:08 PM
ok well what about just some tips or words of advice on changing them...Is it an allen head that I need to use to remove the two bolts that hold the caliper in, if so what size?
Any help is appreciated,
Joshua
musclehead
03-28-2006, 08:45 PM
Joshua
Get a 3/8's allen socket. The tool will snap onto a 3/8's ratchet on one end and have the allen tool on the other end. This socket will allow you to remove the 2 bolts holding the caliper on.
Remove the caliper. Set it on something so that it doesn't hang from the brake line. Swap out the brake pads. Then pull the rotor off. Replace with new rotor. Put the caliper w/new pads on. Tighten up bolts. You are now done. Simple as that.
joshua32
03-28-2006, 10:38 PM
Thank you sir :thumb:
Joshua
musclehead
03-28-2006, 11:30 PM
Joshua
You are very welcome.
