What would you do?
Old 03-28-2006, 09:36 PM
TV559's Avatar
Default What would you do?
I just recently came in to some money and was thinking about doing some more work on my 99 SS. So my question is what would you guys do with $5000. I was thinking about getting a 408 or something like that but just don't know where to start.
Thanks for your input guys in advance
Old 03-28-2006, 09:37 PM
camaroextra's Avatar
id invest it, but thats probably why im still running 13's
Old 03-28-2006, 09:41 PM
Tech Resident
WhiteKnightZ28's Avatar
Well it would help to know what you've already done, but I'm going to assume your mostly stock.
I'd start with a good Head/Cam package, makeing sure you have all the boltons done already.
Then if your an A4 you'll need a stall.
Then I'd spray the bitch, nice 150 wet shot, with that you could put down close to 600hp. Thats more than enough to start breaking things.
Old 03-29-2006, 03:39 AM
TV559's Avatar
My mod list consist of:
TR230 Cam
Most bolt ons
and a Fuddle 4000 stall
I was leaning towards going with a 408 or forging the motor. Just can't decide.
Old 03-29-2006, 08:20 AM
conan's Avatar
Forged bottom end and some heads, If you stay in the stock cubes range both can had for around 5k.
Old 03-29-2006, 08:54 AM
Import Patrol
CrawlinWS6's Avatar
Well, if you are still running the 10bolt, get a 12bolt. Also, I would do a heads cam package.
Old 03-30-2006, 10:18 AM
Mrwilson's Avatar
whats the main reason for gettin a 12 vs a 10?
Old 03-30-2006, 10:31 AM
B-MAN's Avatar
Stronger rear. the sock one will break once you start making power. All it will take is a good hook up at the track and bam!!!!!!! Mosier makes a good 12 bolt.
Attached Thumbnails What would you do?-burnout.jpg   What would you do?-hard-launch.jpg   What would you do?-import-killer.jpg
Old 03-30-2006, 10:54 AM
98Z28MASS's Avatar
My vote is for a good set of heads (mayve afr 205's) and then go with either a moser 12 bolt or a 9 inch rear. That should put you around 5K. You could froge your stock short block but id say sell your stock short block and just buy a new 346/347 block from one of the sponsors as you will recoupe a good amount of the cost from selling your stock short block. With the 408 you are def going to need new heads and with the cost of the forged 408 being around 4K by intself you looking at $1500+ for a decent set of ehads, plus a bigger cam for the 408, better fuel system, etc, etc and it will cost you well over 5K. Plus then your def on borrowed time with your stock 12-bolt and tranny.
Old 03-30-2006, 10:58 AM
ActionJack's Avatar
12 bolt should be on whatever list you have if the money is going into your ride.
Jack
Old 03-30-2006, 10:59 AM
99camarosupersport's Avatar
Originally Posted by camaroextra
id invest it
Old 03-30-2006, 11:05 AM
Allergik2dyin's Avatar
If this is 5k strictly for modding your car then definitely get a 12 bolt and not have to worry about it snapping somewhere down the road. Then go with a head/cam package or something along those lines. If this is just a lump sum of money, I'd probably invest some of it and get a 12bolt just to have peace of mind.
Old 03-30-2006, 04:01 PM
Shallow Bay's Avatar
Is the car payed off? If not, I would put that money or some of it towards that.
Old 03-30-2006, 10:02 PM
rubber duck's Avatar
Old 03-30-2006, 10:53 PM
TV559's Avatar
My car is not payed off but I did pay my car payment for a year. So I don't have to worry about payments for a while.
