fluids for a 99
Old 03-29-2006, 10:23 AM
JDP
JDP's Avatar
Default fluids for a 99
ok guys, ive been searching and reading, i plan on changing my engine oil trans/rear end fluids soon because i just got the car and it has 25k miles on it so i think it would be good to change all the fluids
i plan on putting synthetic oil in the motor and rear (probably Mobil 1)
but heres the problem, i have a 99 t-56 and people say dont use a synthetic because it eats the material on the blocker rings or whatever. then people say use gm syncromesh but ist that a partial synthetic too?
should i just put some mobil 1 atf in there (non-synthetic) because i dont plan on screwing up my trans anytime soon
i searched about fluid for the t-56 and it seems like everybody talks about the trans fluids for 2000 and up transmissions
Old 03-29-2006, 10:31 AM
waiting2bl33d's Avatar
mobil 1 doesn't make a product that isn't synthetic...it would be just mobil but i don't think they make a dexron 3 that isn't synthetic (exxon/mobil) i'd just use some nice non synthetic dexron 3 mercon for the trans. then i put mobil 1 75w-90 in my rear which is where they are saying to put in syncromesh i beileve but just a regular 75w-90 would be just as good.
Old 03-29-2006, 10:41 AM
JDP
JDP's Avatar
also if i use mobil 1 in the rear, do i need the posi additive, because i know royal purple already has it i guess?
Old 03-29-2006, 09:30 PM
JDP
JDP's Avatar
no other opinions?
the threads i foud when i searced didnt give me a real straight answer
Old 03-30-2006, 12:20 AM
yes, you need to use the additive. you can buy some stuff called trans x posi additive thats 5 bucks or the GM additive at the dealer for 10 bucks but remember only 4oz of additive. i love my mobil 1 gear oil
Old 03-30-2006, 07:51 AM
JDP
JDP's Avatar
ok, thanks, im going to do the rear today i think, ill do some more searching i guess to see if i can figure out what trans fluid i should use.
