Drag Racing Tech - Were do you go to get a roll bar approved?
JRracing
03-29-2006, 11:41 PM
How and were do I need to go to get my wolf 6pt roll bar inspected and approved.
Do I need to contact someone at the track around here?
Also, what kind of 5pt harness do I need? I got the crotch strap bracket coming with my new roll bar.
mvonada
03-29-2006, 11:49 PM
Tech inspection will look at it. Never had to show it was certified.
Villain281H
03-30-2006, 12:11 AM
As long as it is installed right, your tech guy should pass it. No sticker or inspection is required like a cage would have, but it must be assembled/welded together correctly. 5 point harness is the 2 shoulder belts the lap belt and the center crotch strap.
Derek
JRracing
03-30-2006, 12:16 AM
So its a cage that has to have an inspection sticker?
Tom the roofer
03-30-2006, 12:23 PM
9.99 and faster for the 10 point cage. Your 6 point does not need certified. Your local track will inspect it.
ls1mongrel
03-30-2006, 12:42 PM
Ive never seena 5 or 6 point fail an inspection, I think if its there and installed good, it will pass !
JRracing
03-30-2006, 05:51 PM
Good to know! Thanks fellaz.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
