getting rid of 5177, I want to go wet, what should I do?
I have had too many problems recently, not related to the kit, but just about everything else So I plan on selling it, the original wiring, noids, custom bottle mount, bottle, jets, lines,wot switch, msd pill kit...hell everything but the switch panel. Maybe the heater and remote opener.
Anyway, sponsors, I plan on keeping my custom wiring set-up if I can, I mean everything is wired to the switch panel and everything is there.
Going wet what would be the best set up? I plan on spraying up to 150. Would you recommend keeping all the accesories? How about the dry to wet conversion? Worth it or not? I'm taking a hit as it is, dont want to really break the bank, but I am basically looking at an entire new kit.
You will be better off selling the system and starting fresh. This way you can get the bigger better solenoids all the way around. If you do just a conversion you will still have the small 5177 nitrous solenoid. I would buy a new system. Your wiring can stay the same since you are just adding an extra solenoid.
Dave
Dave
Originally Posted by JCurtin
^^^^thats what I was leaning towards. Whats the best kit to go with for someone that has the wiring and what not already?
Dave
Originally Posted by Nitro Dave's Nitrous Outlet
There are several ways we can go. We carry many different brands and desighns. Ill send you a pm with some suggestions after lunch.
Dave
Dave
