marine02ss
03-30-2006, 08:47 PM
I have a friend that selling me a 9" center section with aluminum pinion support and 3.70 gears with spool.Everything is assembled for $400 I ve done some research and found the case to be with 1 single web from top to bottom and drain hole,which seems to be the most common one.He told me it has the large bearings on it.My ?s are will the yoke it has,can I still use my stock driveshaft?I would assume I just buy a moser housing with axles and Im done,but Ill probably ditch the spool and get a posi.What do u think, any suggestions and tips are welcome.
