Wiring Question
Wiring Question
Has anyone done the wiring under the strut tower in between the fenderliner mod? I only know one person who has done it before? Anyone know how to do it, how hard it is, or anything?
I've done it, and if you cut the hole in the right place you won't need to extend any of the wires. I was clever and used an LT1 fuel line grommet, but I hear that they are extremely difficult to purchase by themself. I think there are writeups floating around for it but I couldn't tell ya since I did mine long ago. If you look in front of the ECU there is a fairly flat area about 2x3 inches where the wires will run nicely. I'll try to get some pics if you need them.
Here is a pic from the wheel well on a friends car that I was working on. If you can imagine this area, you're looking back towards the ECU. I drilled out those 4 smaller holes to make the radius for the grommet, connect the edges with straight cuts and there ya go.
Tech Resident
As in the !wire mod?
Its been done a million times, heres the link:
https://ls1tech.com/forums/appearance-detailing/173263-completed-wire-mod-tutorial-inside.html
https://ls1tech.com/forums/showthread.php?t=173263
