Is anybody running a Trailblazer torque converter?
Old 03-31-2006, 09:22 AM
Colby 04's Avatar
Default Is anybody running a Trailblazer torque converter?
I'm told the trailblazer torque converter will work in a 2002 Z28. I'm wondering what your opinion is on it? How much more stall does it offer than the factory converter? How much of an improvement did you see?
Now, I understand most will probably post and tell me to spend the money on the vig or fuddle or some other brand. I appreciate those opinions, however, they do not answer the question above. I'm trying to offer my brother-in-law options, and I've been told the trailblazer stall is an option. So I'd like to see how it compares to stock and let him decide. Thanks
Old 03-31-2006, 09:26 AM
jmm98LS1's Avatar
I can't answer all your questions, but I do know that it will work in an f-body. I've read about folks using it on these boards, but search doesn't go back far enough right now to find the threads. IIRC, the stall speed behind an LS1 will be around 2400-2500 rpm.
Old 03-31-2006, 01:34 PM
Ragtop 99's Avatar
The original SLP unit was a truck converter. It helps off the line, but if you have the ASA cam, you need something bigger. Yank SS3200, Vig 2800, TCI 3000 or similar is the smallest you should go.
Old 03-31-2006, 01:38 PM
jmm98LS1's Avatar
You talkin to me or him? I'm putting a fuddle 3600 in mine if you're talking to me.
Old 03-31-2006, 01:52 PM
12 Second Truck Club
white1's Avatar
Colby, I had a trailblazer converter in my truck, and have friends that used them too. I cant tell you what gains over stock they give, cause I went from a TCI 3000 to the trailblazer, so I actually lost performance. But the fix(es) should be here soon
Old 03-31-2006, 04:50 PM
Colby 04's Avatar
did your friends use them in f-body's or trucks?
Old 03-31-2006, 05:29 PM
white1's Avatar
Trucks, what are you thinking about using it in?
Old 03-31-2006, 05:30 PM
white1's Avatar
Doh nevermind
Old 03-31-2006, 07:52 PM
Colby 04's Avatar
Doh nevermind
Old 03-31-2006, 09:50 PM
Ragtop 99's Avatar
Oops, my bad. I looked at the wrong signature. I try to read the sig before answering and got the wrong one.
Quick Reply: Is anybody running a Trailblazer torque converter?
