Whats The Stock Plug Gap
im about to change the wires and plugs and need the gap spec. i usually find it quickly under the hood on most cars, but i cant seem to find it on mine.
edit> i bought taylor wires and the stock wires have the heat shield, they wont fit on the taylor wires. do i need them?
Stock gap on mine is .060, I use NGK TR55's and gap them at .055. Best thing about aftermarket wires for me was not having to ever mess with the heat shields again.
i just found this info so im going to leave them at 40 since these are the plugs i bought.
http://www.acdelcotechconnect.com/p...b_03D-J-171.pdf
1. Your link doesn't work.
2. Don't gap your plugs at .040....that's way too tight for a N/A motor. Gap them around .055
heres the thread about the plugs i bought. they were all at 40 from the box and could be damage if set to 60, link should work now.
https://ls1tech.com/forums/showthrea...spark+plug+gap
Reading the above post link, thinking WTF is truth?!
Have the Delco Iridium plugs in hand and yes they WERE (note past tense) gapped at about .040. I re-gapped them to .055 thinking I was setting them correctly.
WTF?!
WTF?!
