what electric water pumps is everyone using?
Old 03-31-2006, 06:40 PM
Strokinit383's Avatar
Default what electric water pumps is everyone using?
Ive got a buddy who is looking for a replacement for his stock water pump. Hes looking into the electric pumps, specifically at the meziere. Its only rated for 2500 hrs of use, he was wondering if this is normal or if there was a better deal out there. What do you guys suggest?
Old 03-31-2006, 07:28 PM
Greaseymec's Avatar
I'm using a Summit. 2000 miles on it so far.
Mec
Old 03-31-2006, 09:00 PM
93LT1's Avatar
mezir water pump runs great for me so far, nice power gain to.
Old 03-31-2006, 09:33 PM
streetwarrior96's Avatar
CSR works fine
Old 03-31-2006, 10:02 PM
hvyss's Avatar
Had a CSI ( before it went to CSR) and got 500 miles out of it. Bought a Meziere and have put 5000 miles on it with no problems.
HVY SS
Old 03-31-2006, 11:29 PM
Camz450's Avatar
I am using the csr, I have gotten 15,000 miles 1 1/2 years it gave sgnificant gains and was easy to install. Some other pumps require cutting fan shroud. With a 160' thermo and a cooling fan tune car never gets over 185 degrees.
Old 03-31-2006, 11:47 PM
aggiez28's Avatar
i havea csr for sale
pm me if interested
brook
Old 04-01-2006, 12:36 AM
rob97TA's Avatar
im using a csr, doesnt go over 180 or so for me either, works great. but i did have to trim my fan shroud a little so i could get the water pump back in.
Old 04-01-2006, 08:50 AM
30th TA 0219's Avatar
DITTO HERE!
Old 04-01-2006, 09:39 AM
OutlawZ's Avatar
I'm using the CSI..... when it was CSI... don't have any long term results from it cause i tore my motor down shortly after i installed it....
I know that it was a PITA to modify the housing the fit the little "ears" on the csi pump tho..... had to get some tig welding done to it as well to seal up the weep hole and plug the driveshaft hole....
Old 04-01-2006, 12:23 PM
radd's Avatar
i have the csr/csi water pump and its 1 1/2 yrs going but my car has been down for 6 months of that time =) but when the car was running i was scared the car wasn't reaching open loop =O usually set around 160 - 165
the install was easy put grinding compound on the ears and set it on the housing then used the die grinder and a aluminum bit 20 mins later it was on the car
Old 04-01-2006, 12:43 PM
TwoFast4Lv's Avatar
CSI(now CSR)
Have 7k on it and over 4 years
With it and a Be Cool Radiator it is hard pressed to even turn the fans on
Quick Reply: what electric water pumps is everyone using?
