Gears & spray?
Gears & spray?
I ordered my 12 bolt with 4.56's before i ordered the spray so i didnt realize I will probably run outta gear by the end of the track right? What if i went to 4.10's? My buddy said 3.73's would be great for the mods I have in my sig, what do you guys think I should do?
You are in trouble with 4.56's. With your set up, 3.73's would be the best depending on the size of tire you will be running. Get into 28 inch meats and 4.10's will be better.
Also noticed in your set up you stated 4L60E or 400. Do not waste any money on building a 4L60E, with what you are doing to the car, go straight to a TH400.
Good luck.
Good luck.
