clutch line wont go into trans
Old 04-01-2006, 02:35 PM
ScreaminSS01's Avatar
Default clutch line wont go into trans
I replaced the clutch several months ago and got hung up with the clutch line going into the trans. I kept putting it off and now its getting warmer and I want to sell the car. Anyways no matter what I do the end will not go into the trans. I am not sure if you need to push it in or does the plastic lock keep it in? Any help would be appreciated!
Old 04-01-2006, 10:43 PM
mrhzk35404's Avatar
The plastic lock is used to unhook the line not to keep it locked.
Old 04-02-2006, 09:05 AM
so what am I doing wrong then? How far does it get pushed in?
Old 04-02-2006, 09:32 AM
Farmer2's Avatar
Try opening the bleeder up when pushing it in. Preasure built up from the clutch install could be working against you.
Old 04-02-2006, 08:27 PM
The PAT WS6's Avatar
yeah crack the bleeder valve then it will snap right in
Old 04-02-2006, 09:34 PM
SSinisterTX's Avatar
it should snap right in
Old 04-04-2006, 11:20 AM
sorry for the dumb question but where exactly is that at?
Old 04-04-2006, 11:43 AM
Mike44138's Avatar
On the top of the bellhousing right about the quick disconnect line. Feel up there and you'll feel a little square hole with the bleeder valve in it.
