Fuel Rail/Injectors Assembly
Old 04-01-2006, 04:46 PM
emj2006's Avatar
Default Fuel Rail/Injectors Assembly
I just recently took off my complete fuel rail assembly and regulator. I have a new fuel rail assembly and regulator ready to put on, but I was just wondering if you have to clean the injector "holes" (where the injectors connect on the manifold). Keep in mind that this is of an lt1 engine.
Old 04-01-2006, 09:16 PM
savethelinoleum's Avatar
that's a good question... I just did mine but I didn't clean those ports... nothing I read said that it needed to be done, but I wondered the same thing..
Old 04-02-2006, 11:00 AM
Syxx613's Avatar
no u dont HAVE to clean them up. maybe just make sure theres nothing in there that will create a problem. however if ur installing ur injectors back in the manifold u better put some lube on the o rings on the injectors or u will most likely have a bad seal and create a vacuum leak. use vasoline, it has many uses ha ha.
Quick Reply: Fuel Rail/Injectors Assembly
