how much will a th350/400 swap cost me?
Old 04-03-2006, 09:48 AM
99SeanWS6's Avatar
Default how much will a th350/400 swap cost me?
im sick of rebuilding my 4l60e, my 4th one just went out so i think im gonna go with either a th350 or 400. im wondering how much everything, trans, swap and things needed for the swap, are gonna run me.
Old 04-03-2006, 10:54 AM
PREDATOR-Z's Avatar
Not including install I've done some research and parts would be anywhere from 2500>2900
Old 04-03-2006, 11:42 AM
LS1TECH Sponsor
Steve Burger's Avatar
Well Built TH350 1750.00
Well built TH400 1300.00
Custom converter 800.00
Shelf converter 550.00
Flexplate 200.00
Dip Stick 80.00
New cross Member 200.00
Shifter 150.00 and up
CM Drive Shaft for TH400 350.00
TH350 can reuse stock driveshaft. But why?
Fluids 100.00 Good Stuff
Odds and ends 100.00
That's all I can think of.
Old 04-03-2006, 12:55 PM
mvonada's Avatar
Ditto on Steve's post. Just doing a Th400 on mine now. Got $3390.00 in tranny, converter, cross member and shifter, no fluid or drive shaft yet. So if done right, you are pushing the high side of $4,000. Not cheap but you only do it once.
Old 04-08-2006, 01:33 AM
revtime's Avatar
If your patient you can get a good deal on a used setup.
I got these for about 1800
Rossler TH400 with JW ultrabell, reverse manual valve body, and transbrake.
Coan 4000 stall with antiballooning plates.
Dennys Nitrous ready driveshaft
B&M Hi Tek cooler with perma cool fan and braided tranny lines and AN fittings.
I then purchased
B&M SFI flexplate 153 tooth.
Tranny temp guage
BMR conversion crossmember with TA mount.
B&M Pro Stick shifter.
I have less than 2500 in the whole setup.
Old 04-08-2006, 09:11 AM
b00sted's Avatar
I'm swapping to a built th350 with a fuddle and stuff...I've got about 2 grand into it right now...Still gonna need some odds and ends. That's with running a stock flex plate and a stock shifter setup.
Old 04-10-2006, 12:54 AM
SUX2BU's Avatar
$2000 -$4000 depending on parts, used/new, and who builds it.
Old 04-10-2006, 06:44 AM
blackbirdls1's Avatar
Would this tranny be the ideal thing to do if the 4l60e goes out?
Old 04-10-2006, 09:51 AM
99SeanWS6's Avatar
i think most people would favor the 4l80e b/c of overdrive
Old 04-10-2006, 10:15 AM
smmurf86's Avatar
i just ordered a th350, havent got it yet but check out maddogtransmissions.com real good prices...also make sure you get a 9" tailshaft...i mess up and ordered one from jegs with a 6" and had to return it. good luck and if antmore question let me know
Old 04-10-2006, 03:20 PM
Restricted User
CAT3's Avatar
I got my Rossler Terminator II TH350 (Transbraked, and RMVB) from a fellow user here, with Flexplate, TC, Xmember, Shifter, Cooler for $1650 shipped to Hawaii. I have enjoyed almost every minute of it, gas mileage takes a hit, but helps being on island. New, I priced out everything was looking at $3200 for comparable components.
The 4L80E is an expensive bastard, but one I may look into converting too.
Old 04-10-2006, 04:24 PM
SUX2BU's Avatar
i think my rundown was like this, just under $2500
th350, transbrake, RMVB = $1000
8" 5,350 converter = $900
B&M aluminumk +3 qt tranny pan (optional) = $115
B&M pro racthet shifter = $170
98-99 stock LS1 flywheel = $50
36" Lokar dipstick = $71
11"x11"x1.5" B&M supercooler = $90
tranny lines and fluid = $20
tranny temp gauge = $50
crossmember = FREE made my own
driveshaft = FREE reused the same one
Old 04-10-2006, 04:39 PM
SUX2BU's Avatar
And i sold all my M6 stuff for asbout $1500
T56 tranny, Mcleod master, ram clutch & flywheel, stock slave, Pro 5.0 shifter
Old 04-10-2006, 07:51 PM
mshadow's Avatar
You guys should shop aroud you can get very good rebuilds on th350s for $700 or so....maybe less.
And you can also get a Fuddle convertor that bolts up to your flex plate for $400ish
Stock drive shaft can be reused....with the long tail th350
You can use your stock shifter with a little modification.....
This swap does not have the break the bank.....
Old 04-10-2006, 11:45 PM
Restricted User
CAT3's Avatar
All that info you posted is not 100% accurate...you really should say "some can reuse stock DS". I was able to run my car with the stock DS, however, no way in hell I was going to race on it with only 3/4-1" installed depth. Sure the axle rotating upward on launch places it deeper in, but then there is wheel hop where the housing is moving and can offset the depth, bottom line, not all can use it. Yes, I have adjustable LCA's and centered the tires too.
Charlie
Old 04-11-2006, 09:16 AM
99SeanWS6's Avatar
i found a really good deal on pretty much everthing needed and a built 400 for $1k. ive never done anything this big with cars so is it something i could do myself in my garage or should i look into having someone do it for me?
Old 04-11-2006, 05:47 PM
ls1_doc's Avatar
What about the torque arm where would that end up going ?
Old 04-11-2006, 06:04 PM
SUX2BU's Avatar
you can either buy a crossmember with a built in TQ arm mount, get a body mount TQ arm or get a spacer/700r4 tail shaft/700r4 TQ arm clamshell put on your tranny and mount the TQ arm up just like stock.
Old 04-15-2006, 10:31 AM
Strahley's Avatar
My swap only cost me about $200, since I traded my M6 for a complete th350 setup. Try to trade your tranny for another one to avoid big costs
