Just ordered new tranny!
Just now ordered it:
FLT Level 4 4L60E Transmission
FLT performance pump
FLT sleeved input drum
8 B/W high-energy clutches in 3-4 pack
FLT beast shell w/bearing
B/W 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Wide 2-4 band
Bushing kit
All solenoids
Internal wire harness
Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated accumulator pistons
Set end play to performance specs
Installed Options:
Vacuum Mod Kit
Sonnax Super Hold Servo
It should be here in 7-10 days. Now I need to call Yank and order new stall and find a new flexplate!
Corvette Servo
Wide 2-4 band
Bushing kit
All solenoids
Spacer plate
B/W clutches
Seal & gasket kit
Filter
Installed Options:
Vacuum Mod Kit
Also got a new flexplate from GM part number 12580709. I thought I should replace it also while I am doing all this work. I have Prothane motor mounts to put in before the new tranny arrives. I also have to get my LCA relocation brackets welded on.
12 Second Truck Club
Damn, 7-10 days? Ive been waiting on mine for 3 weeks+, but I got the level 5, and they said it took a while for all the parts to be treated, and machined. Oh well still waiting on my converter anyway.
Originally Posted by BLWN1
Where in S Indy are you? What do you want for your old flexplate?
Originally Posted by BlackHawk T/A
You will love it. Same one i'm running. Looks like you even copied/pasted from my thread, makes me wonder how much business I did for FLT with that post.
